Author: Subject: OEM Water / Oil heat exchanger
se7ensport
posted on 23/9/19 at 10:09 PM Reply With Quote
Suggestions wanted, I'm looking for something comparable to a laminova without having to spend out £250+
I'd go with a Modine that fits between the oil filter and take off plate if I could find a new genuine one.
Intended use is a race Duratec engine, it uses 32mm and 25mm water pipes and jic 12 oil.
Theshed
posted on 24/9/19 at 02:09 PM Reply With Quote
A little cheaper and everybody needs a bit of Ferrari
https://www.ebay.co.uk/itm/Genuine-FERRARI-355-oil-to-water-HEAT-EXCHANGER-cooler-Part-No-180846/292828229873?epid=15027218490&hash=item442dec30f1 :g:Cp4AAOSwe~lb9m44
se7ensport
posted on 24/9/19 at 07:34 PM Reply With Quote
I’d spotted that a couple of days ago, it would be great, but the water hoses are 76mm!
posted on 24/9/19 at 08:39 PM Reply With Quote
Rover 75 V6 (nb not diesel which looks similar)
https://www.the75andztclub.co.uk/forum/imagehosting/95849b0e50f1601d.jpg
DH2
posted on 29/9/19 at 01:45 PM Reply With Quote
Can you not use the OE Duratec one?
DH2
