trialsman
posted on 16/1/20 at 05:07 PM |
Trying to replace front plastic bushings
I'm trying to replace the control arm bushings on my English made Locost. The outside diameter of the metal tube they are in is 1.35"
(34.29mm) X 1.2" (30.48mm) long and that includes paint. The bushings are red plastic and two piece with a larger flange on the outside of each
right and left. I'm trying to find out what the bushings are before I disassemble then. Any suggestions? Are they Spitfire bushings? I'll
try to post pictures later if that will help. Russ
gremlin1234
posted on 16/1/20 at 08:03 PM |
they don't sound like triumph spitfire bushes,
do yours have a central metal tube ?
a picture would really help ;-)
posted on 17/1/20 at 08:28 AM |
Have a look at the Superflex website the kitcardirect and the rally design websites. It may be a common locost bush kit?
Mr Whippy
posted on 17/1/20 at 01:00 PM |
you need to push them out and measure them, could have come from anywhere but at least if you know the sizes you can move forward
English made... that probably accounts for at least 75% of all lotus 7 clones, can you tell if it's home made or a kit manufacturer?
[Edited on 17/1/20 by Mr Whippy]
trialsman
posted on 17/1/20 at 02:24 PM |
It appears to be a homemade, I assume, but it is an awfully well made one. There is an alum. plate in the engine compartment that has what I assume is
a VIN. It says "R SIERRA LD" and an 11 digit serial number that starts with "BBAFUB.....". There may be a letter or number in
front of the first "B".
40inches
posted on 17/1/20 at 02:56 PM |
This site has dimensions, there are others in the catalogue.
Rally Design
gremlin1234
posted on 17/1/20 at 03:38 PM |
a very quick search on that number brought up this very intersting (well certainly for you) thread
https://www.locostbuilders.co.uk/forum/7/viewthread.php?tid=85695
oh, I find it was your own thread from 12 years ago
[Edited on 17/1/20 by gremlin1234]
posted on 18/1/20 at 09:41 PM |
The OP started that thread
posted on 18/1/20 at 10:02 PM |
Oh I find it was your own thread from 12 years ago . Think that gives you a clue?
obfripper
posted on 18/1/20 at 11:00 PM |
The chassis number is from the donor vehicle, BB- Gt Britain, Halewood produced, AF- Escort 4 door, UB produced Sept '78, the rest of the
chassis number will be the same as the original escort engine number.
Dave
trialsman
posted on 19/1/20 at 12:41 AM |
Wow, that's good info to know. Any idea what the other number is? ARFDMJ E###
obfripper
posted on 19/1/20 at 10:55 AM |
Looks like some of the build plate numbers (would have originally been on the slam panel on the opposite side to the vin plate).
The A is escort, R is rhd , F is 4 door saloon, D is base model, M is manual, J is 1300cc, the rest i'm not sure on, but are likely to be trim
and options.
Dave
obfripper
posted on 19/1/20 at 11:10 AM |
Just to add, the SIERRA is the original colour(a fawn beige, and the colour of the build plate if original) , R should indicate Recaro seats but may
mean something different on a base model, LD i''m not sure but should be external trim options.
Dave
