Author: Subject: carbs?
paul_mcq
posted on 27/1/05 at 11:23 AM Reply With Quote
carbs?
i have a su carb size 1.5 inch would i be best using it or a weber 45 for a slightly tuned 1275 a series? plz get back. cheers
white130d
posted on 27/1/05 at 12:15 PM Reply With Quote
Yes
You can run a 1.5 with a red spring BQ needle (according to page 93 of Tuning the A Series Engine by David VIzard).
I run a 1.5 with a blue spring and E3 needle on my 998 with a mod. head and 3 branch.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
timf
posted on 27/1/05 at 12:31 PM Reply With Quote
1275 go for an 1 3/4 hif su or a 45 on a proper manifold
posted on 27/1/05 at 12:42 PM Reply With Quote
Weber is not a lot of gain for the money including jetting etc. S.U. is easier to keep in tune and much more available, also more economical on fuel. If you can get a twin S.U. setup even better
white130d
posted on 27/1/05 at 12:51 PM Reply With Quote
For the 1275 I am building for the 7, I have both a set of 1.25 SUs and a 45 dcoe set up. I want to experiment using the Vizard book set ups to see if I can tell the differences. The Weber should be better at top end and the SUs should pull well but start to loose a little at top end. I have a feeling I will be happiest with the SUs.
D.
posted on 27/1/05 at 04:33 PM Reply With Quote
Vizard book is well and truly out of date find a late MG Metro in the scrappies and use everything off that -- find one late enough and will even have hardened valve seats for unleaded.
posted on 27/1/05 at 06:05 PM Reply With Quote
MG manifold can also be modified to make it even more efficient, worked well on my old mini pick up with modded MG engine, pulled like a train and gave good economy if driven sensibly.
