r1_pete
posted on 21/6/20 at 12:30 PM |
Crank spigot bearing Phosphor Bronze or Needle...
I have both PB and Needle bearings for my Ford V8, but cannot decide which to use....
Needle sounds better, but it has several parts, and breaking up is not unknown...
PB is just a single lump, nothing to go wrong really....
As the bearing does nothing unless the clutch is pressed, I'm leaning towards phosphor bronze....
But looking to the collective wisdom here for any thoughts.....
Oddified
posted on 21/6/20 at 07:40 PM |
Used both over the years, i prefer using roller bearings.
Ian
posted on 21/6/20 at 08:08 PM |
I’ve had problems with needle roller bearings siezing on a few occasions and also with PB s coming loose or squealing due to drying out. My preference
is needle roller
chillis
posted on 24/6/20 at 01:01 PM |
Needle roller or ball bearing every time. People only have problems when they fit them back to front, the dust seal needs to face the clutch.
Never under estimate the ingenuity of an idiot!
posted on 24/6/20 at 02:30 PM |
quote: Originally posted by chillis[/ People only have problems when they fit them back to front, the dust seal needs to face the clutch.
Not so, VW air cooled and some water cooled, the bearing is already installed in the flywheel securing bolt in the factory, I’ve had a few that have
caused problems.
perksy
posted on 24/6/20 at 08:40 PM |
Needle Roller
