New Topic New Reply
Author: Subject: sierra rear suspension
wanderinstar
posted on 30/1/05 at 05:41 PM Reply With Quote
If you use Sierra as donor can you use Sierra rear axle crossmember,lower suspension arms springs and shockers?
Wanderinstar.
undecided
posted on 30/1/05 at 05:46 PM Reply With Quote
It would be a tad heavy not too mention look crap
posted on 30/1/05 at 06:04 PM Reply With Quote
the springs are far too powerful for such a light car, and the pick up points arent ideal for either the springs or shockers.
i have used the rear subframe and trailing arms, with brackets welded on for gts shocks. Whilst it has saved me some time, i would strongly advise others not to bother - it weighs a crapload, and is quite wide (hard to cover by bodywork).
much better (more satisfying) to make a 'proper' backend.
[Edited on 30/1/05 by JoelP]
blueshift
posted on 31/1/05 at 04:58 PM Reply With Quote
Buy a GTS dedion kit and be done with it.
New Topic New Reply
