Stevestriker750
posted on 4/1/22 at 10:11 AM |
X FLOW BHP GAINS
Hi all,
Is it worth trying to squeeze more bhp out of a x flow?
My car currently has a 1700cc with fast road cams and twin Webers
Mike Wood
posted on 4/1/22 at 12:54 PM |
Depends what your objectives and budget are as well as if the car is trying to fit in with any race or speed event series.
1700cc on twin 40 sidedraft Weber carbs is a classic recipe for Seven type cars, probably up to about 135bhp. Beyond that can get expensive to get
more power from a Crossflow as well as maybe a different kind of fun and driving car. You might want to investigate Ford Zetec, Rover K Series or more
modern car engine swaps or the bike engine route.
What gearbox are you running? Back axle? Brakes?
Mike
PS could be interested in the engine, gearbox, carbs, manifolds etc for my Locost project . Is it under 1700cc, e.g. 1690cc?
[Edited on 4/1/22 by Mike Wood]
MikeR
posted on 4/1/22 at 08:37 PM |
Define fast road cam - it's possible more power from a better cam, or improved running/setup. Better drivability would be from electronic
ignition or ignition and fuel injection.
(I'm working very slowly on a bolt on manifold to use the Weber as throttle body and position the injectors under the Weber's)
snapper
posted on 5/1/22 at 07:14 AM |
There are injection converted Weber’s available where the injectors are in the carb body, they look just like carbs, very retro.
I eat to survive
I drink to forget
snapper
posted on 5/1/22 at 07:23 AM |
Depends on a lot of factors, if you have high compression pistons (1300) you may need cutouts in the pistons if running standard oversized pistons
then you could push to a 223 or even a 224 camshaft
I eat to survive
I drink to forget
MikeR
posted on 5/1/22 at 08:58 AM |
I'm aware of these and like them very much, but they're not cheap (although I don't think that expensive) and I wanted to try and do
my approach for much less.
Mike Wood
posted on 5/1/22 at 10:23 PM |
If you search for info on ‘Ford Crossflow all steel engines’ you will get a flavour of the next big jump up level of Crossflow builds used in some
competition cars, such as hillclimb and circuit racers sports racers (such as Mallocks including in historic Clubman’s races) as well as short circuit
cars:
http://www.turbosport.co.uk/showthread.php?t=988232
https://racecarsdirect.com/Advert/Details/98210/ford-crossflow-all-steel-engine-209-bhp-ax-bl
‘All steel’ refers to using specially made racing components for the crankshaft (such as by Farndon) and the connecting rods as well as aftermarket
pistons. IIRC engine builders for such power plants include companies such as Auriga, MASS, Philspeed, Connaught etc.
Guess you have seen: https://www.burtonpower.com/tuning-guides/tuning-guide-pages/ford-kent-crossflow-tuning-guide.html#
You may want to optimise what you have and then do a swap to a different engine type to get a bigger increase in power on a sensible budget; i.e.
reached the end of sensible Crossflow mods and can then get easier power gains and also something with a tractable power curve.
Mike
[Edited on 6/1/22 by Mike Wood]
