pitesy
posted on 19/1/22 at 09:57 PM |
MX-5 engine swap gearbox mount
Hi guys,
I am currently preparing to install a 1.8 vvt MX-5 engine in my RX-7.
As the MX-5 has a power plant frame thingy that connects the gearbox to the diff, the fabrication of the mounts looks to be a bit awkward.
How did you mount your gearbox? I have seen a swaps done on the forum, but not many pictures. Ideally I would attach something to the part where the
PPF goes normally and not where the 2 threaded holes are below the shifter. It goes in a heavier can than the MX-5 and it will be turbocharged
eventually as well and I'm unsure about how strong those are.
Thank a lot for your ideas and help!
Best regards
Stefan
[Edited on 19/1/22 by pitesy]
chillis
posted on 20/1/22 at 05:32 PM |
Does the RX7 not have a PPF?
Never under estimate the ingenuity of an idiot!
pitesy
posted on 20/1/22 at 05:37 PM |
Thank you for your input!
Gladly the FC does not have one, only the FD and the RX-8.
