Author: Subject: Cat fitting
Steve Lovelock
posted on 2/2/05 at 05:16 PM Reply With Quote
Cat fitting
I am looking at the cheapest possible way of getting as much BHP into my Luego XT chassis as possible. One of the engines I am thinking of is the Duratec with bike throttle bodies and a megajolt system. If I were to use such a new engine then I presume that I will need a cat for the exhaust system for SVA and I am interested to know how I could fit one to a '7' type car without it looking shocking? What is the usual route for this?
posted on 2/2/05 at 06:19 PM Reply With Quote
Try these.
http://www.autocats.com/html/About.htm
CairB
posted on 2/2/05 at 10:19 PM Reply With Quote
One way is to get the car through the SVA with a cheaper, quicker installation engine from pre '95, a pinto perhaps. Then at some later date upgrade to something like a Duratec with the exhaust coming out the same side. To the best of my knowledge the car will retain its original emmissions requirements. I would expect that the Duratec would be better on emmisions than the pinto without a cat. So everyones happy
Perhaps someone could advise if this is not the case regarding emmision requirements.
Colin
wilkingj
posted on 2/2/05 at 10:25 PM Reply With Quote
Put anything old in, and get a Q plate.
Problem solved.
Best Regards
Geoff
http://www.v8viento.co.uk
