Author: Subject: Plastic bumper repairs
Dingz
posted on 27/12/22 at 10:10 PM Reply With Quote
Has anyone repaired successfully fixing tabs on a plastic bumper? Daughter has Citroen C1 and damaged the bumper, looks like most of the lower tabs have broken. Wondered if there was any suitable adhesive or fillers. Looks like 3m may do one.
Thanks.
went on and on.
Mr Whippy
posted on 28/12/22 at 01:09 AM Reply With Quote
I've done repairs to plastic bumpers simply using a soldering iron and scrap plastic to weld the splits together. Dead easy and I used this method all the time with my 3D printed models. Its also how caravans are repaired. Glues just don't stick. Finish off with some normal body filler.
cliftyhanger
posted on 28/12/22 at 12:09 PM Reply With Quote
As above, I have used a soldering iron but I have also often used bits of paperclip as reinforcement. There are videos on youtube to give you the idea.
posted on 28/12/22 at 06:28 PM Reply With Quote
You can also get a proper plastic welding kit which contains metal staples that you heat up. Essentially it's a posh version of the paperclips / soldering iron technique.
coyoteboy
posted on 28/12/22 at 07:30 PM Reply With Quote
https://tinyurl.com/mry2v9y4
Plastic welder. Instructions on YouTube.
[Edited on 28/12/22 by coyoteboy]
https://www.fixmystreet.com/
Dingz
posted on 29/12/22 at 01:22 PM Reply With Quote
Thanks very much for the suggestions looks like welding technique is the way to go.
went on and on.
SteveWalker
posted on 29/12/22 at 01:28 PM Reply With Quote
Are these tabs on the underside/back of the bumper, where they cannot normally be seen? If so, I'd just use strips of plastic, screwed to the bumper.
