coyoteboy
posted on 30/10/23 at 04:09 PM |
Bonnet bumper rubber
I have a car that is knocking on 30 years old now and the bonnet hinges are getting a bit of play. They're pressed items and not adjustable, and
now while the bonnet is latched I get constant scratchy jiggly rattles as it goes over bumps and the body flexes. It's driving me nuts.
In an effort to diagnose it, I trapped some neoprene under the hinge area to just preload the hinge a little upwards and this silenced the
nuisance.
Is anyone aware of a location to buy firm rubber strip that is bond-on, or adjustable height bumpers that I can cut and bond? The neoprene compressed
and the rattle returned after a week.
Schrodinger
posted on 30/10/23 at 04:20 PM |
How about CBS https://www.carbuilder.com/uk/self-adhesive-strip
Trim strip
Keith
Aviemore
posted on 30/10/23 at 04:40 PM |
You might give Woolies a look
https://www.woolies-trim.co.uk/p-1726-flat-black-rubber-strip
gremlin1234
posted on 30/10/23 at 09:08 PM |
draft excluder tape
https://www.amazon.co.uk/foam-tape/s?k=foam+tape
https://www.amazon.co.uk/DIY-Doctor-Adhesive-Stripping-Excluder/dp/B091HPDSH4
coyoteboy
posted on 31/10/23 at 01:44 PM |
Thanks for the suggestions folks, problem is they are all a bit soft, the neoprene I used was an old kneeling pad 10mm thick and that rapidly
compressed and stayed compressed.
I see a bunch of screw-in rubber stops but I dont have any screw threaded holes and I'm not planning to drill any but im sure there must be bond
on options my Google foo is failing me for.
posted on 31/10/23 at 03:19 PM |
Any chance of replacing the actual hinges to overcome the wear?
coyoteboy
posted on 31/10/23 at 03:31 PM |
Discontinued, online sources are pushing the price up to 75 quid per side 😭
Dingz
posted on 2/11/23 at 08:37 AM |
I think you’ll find most foams will take on a set quite quickly, try a solid but low shore solid rubber if you can.
went on and on.
gremlin1234
posted on 2/11/23 at 08:46 AM |
how about stick on rubber feet
https://uk.rs-online.com/web/p/enclosure-accessories/1368967
there is a range, all self adhesive except 136-8970
coyoteboy
posted on 2/11/23 at 08:50 AM |
I couldn't find anything the right shape/firmness so I'm going to go with the rubbers off a similar vehicle and cut and bond them.
  Surf Bonnet Rubber
coyoteboy
posted on 2/11/23 at 10:40 AM |
do RS still do private customers?
gremlin1234
posted on 2/11/23 at 12:25 PM |
I just checked, yes they do, you can even buy stuff as a guest, without registering
I think for Farnell, you use cpc as a private customer.
ps, I noticed the item I linked to is on back order.
coyoteboy
posted on 2/11/23 at 12:27 PM |
Ah nice. I moved to NL a couple of years ago and they won't sell to private folk in europe, but while I'm back in the UK I will order from
there. Thanks for the heads up!
