rug
posted on 15/3/24 at 11:42 AM |
duratec - no oil pressure
So I am at the point of starting my motor.
While cranking I see no oil pressure. I took the oil pressure sensor off and I have no oil on the end so I am not getting any oil circulation at all.
I have a custom oilpan and I have had the oil pump out and back in so the oil system was completely empty before I filled it back up and cranked it
over. Does the oilpump need to be primed somehow? Or am I stuck taking the pan off and start looking for other faults?
rug
posted on 15/3/24 at 02:05 PM |
Solved! I used a syringe ansd squirted some oil into the port towards the oil pump under the oil filter. Now I have pressure!
Mr Whippy
posted on 15/3/24 at 07:46 PM |
Remember to fill the oil filter before putting it on (unless obviously if it sits on its side...) as they can hold lot of oil. My Volvo takes a whole
litre which it otherwise would have to fill before anything got to the bearings. But glad you spotted the issue and sorted it
posted on 16/3/24 at 01:46 PM |
Vaseline in the oil pump when assembling an engine was common practice at one time
