Author: Subject: Cyl head tool
scoobyis2cool
posted on 6/2/05 at 03:46 PM Reply With Quote
Cyl head tool
I'm stripping down an old 1600 pinto for a bit of experience but haven't got the right tool to get the cylinder head off - it's a star bit fitting but the ones with my tool kit aren't quite big enough. Does anyone know what size I need before I go on a hit-and-miss trip to Halfords?
Pete
posted on 6/2/05 at 04:20 PM Reply With Quote
Most motor factors do a kit with 2 in it. One for the head bolts and t'other for the timing belt tensioner for a few quid. Laser tools I think manufacture them.
mattdearden
posted on 6/2/05 at 04:54 PM Reply With Quote
Torx
I too am in the process of removing the head on my Pinto to fit a fast road cam
The thing you're looking for is called a Torx bit. You'll need a T55 (this is the size) with a 1/2 drive (assuming your torque wrench is). Halfords should sell them.
Job done
Matt Dearden
(2lt Pinto Cat)
http://www.cate1.co.uk
http://www.swtoc.co.uk
scoobyis2cool
posted on 7/2/05 at 10:45 AM Reply With Quote
Thanks for the help guys, just about to pop out and buy it now. I took my timing belt tensioner off the other day - for some reason there was no torx bolt like in the Haynes manual, it was just a standard bolt! Never worked on an engine before so wasn't sure if there was a good reason behind this. Not that I'm bothered, this is just a spare engine, not planning on getting it up and running again.
Pete
mattdearden
posted on 7/2/05 at 11:15 AM Reply With Quote
Pete
The Pinto went though a change in about 1984 IIRC.
Before that the head bolts were normal headed ones that didn't require any special bit, but the cam-belt tensioner was with a spring that was held in place with a Torx headed bolt.
After 1984 they changed the head bolts to the stretch ones with Torx heads and the cam-belt tensioner is held in place with 2 normal headed bolts
Matt Dearden
(2lt Pinto Cat)
NS Dev
posted on 7/2/05 at 01:31 PM Reply With Quote
if you can get hold of some bolts from an earlier engine then it's worth doing if you plan a series of mods as money allows, that way you don't have to renew them each time.
theconrodkid
posted on 7/2/05 at 04:48 PM Reply With Quote
wernt the early ones fine splined and laters torx?
who cares who wins
pass the pork pies
posted on 7/2/05 at 04:57 PM Reply With Quote
Pinto head bolts were splined from day 1 of the Mk3 Cortina -- it was first time I ever saw a that type of bolt..
Just to add I have a spare splined tool if anybody needs one.
[Edited on 7/2/05 by britishtrident]
jollygreengiant
posted on 7/2/05 at 05:01 PM Reply With Quote
Correctomundo Conrod. Early pinto's were multi-spline (12 point like a double hex) and the later ones were Torx ( 6 point with deep concave between points). I think the multi spline were m10 or m12 and the torx is T55. (PS. DO NOT confuse torx with the italian {fiat et al} Ribe system.)
Welcome to the land of dealer specific bolt fixings. Enjoy.
scoobyis2cool
posted on 7/2/05 at 08:45 PM Reply With Quote
Not necessary on this engine, I'm just stripping and rebuilding it with the parts it already has, not planning on ever using the engine so I don't plan on spending any money either!
Stripped it down today, the internals actually look pretty decent even though the outside was a complete state. Had a couple of problems which I've detailed in THIS THREAD if anyone fancies helping out
Pete
