jacko
posted on 10/2/05 at 06:53 PM |
prop shaft
Hi all does anyone know the measurements on a sierra prop shaft from the diff flange to the centre hub bearing bolt holes so i can weld a plate in a
chassis . Im converting from car engine to bike engine and dont have a prop yet thanks Jacko
| posted on 11/2/05 at 04:29 AM |
Will measure over weekend unless someone posts before....
| posted on 11/2/05 at 12:35 PM |
BTW - What made you decide to go Bike engine Jacko?
mookaloid
| posted on 11/2/05 at 01:44 PM |
Hi Jacko,
Sorry to hear you are leaving the Pinto fold - I really liked what you did with the SU's
Good luck anyway
Mark
DarrenW
| posted on 11/2/05 at 02:45 PM |
Apologies for the thread hijack.
What did you do with the twin SU's Jacko? How did they work compared to the more conventional route?
| posted on 11/2/05 at 03:34 PM |
Laid out flat
From the face of the rear flange to the start of the centre bearing is 880mm. The boltholes are elongated and the carrier is 65mm wide.
jacko
posted on 11/2/05 at 07:37 PM |
Confession - a misunderstanding I am not changing my car engine Im doing it for a mate.
Peteff - Thanks for sending the measurements I needed.
Darran- The SU carbs I have fitted are from two metros 1300cc and a home made manifold. Im very pleased with the performance. Im going to try
different needles when I get the car back on the road. If you look in my photo archives you will see some pictures. U2U me if you need more info.
Mark- Dont be daft I wouldn't leave the pinto family Ive just had a lot of mods done to my engine to blow you of the road. Good luck with the
hill climbs this year.
Hellfire- Thanks for the offer of getting me the measurements and as above you can see im keeping my pinto for now anyway.
All the best Graham. [Jacko]
mookaloid
| posted on 12/2/05 at 11:24 AM |
Hi Jacko,
Very relieved to hear it - I will be very happy if you can 'blow me off the road' - but I doubt it
Look forward to seeing you this year
Mark
