Author: Subject: Polo rad
Chris_R
posted on 14/2/05 at 10:17 PM Reply With Quote
Polo rad
Picked up a Polo rad at the weekend and it's tiny. Will it cool a 2.0 Pinto?
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
MikeR
posted on 14/2/05 at 10:18 PM Reply With Quote
aye lad, the only problem you'll have is trying to fit it in, they are a TIGHT fit!
Chris_R
posted on 14/2/05 at 10:20 PM Reply With Quote
is that the Pinto or the rad? Are there any better alternatives?
zetec
posted on 14/2/05 at 10:53 PM Reply With Quote
The rad, takes a bit of playing around to get it to it. The good news is the tighter it is in the nose the more air flow and cooling you get. should be good for 4 pots up to 250bhp ish.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
marshall
posted on 15/2/05 at 06:46 AM Reply With Quote
i have fited one in my tiger avon and
it fits in nice a man from the swtoc had
one fited to his cat e1 with a 2.0 pinto and it was ok ....
Bob Green
posted on 25/2/05 at 06:35 PM Reply With Quote
Polo Rad
A Polo rad will work very efficiently with a Pinto engine.
tks
posted on 25/2/05 at 09:50 PM Reply With Quote
POLO Donor question
from wich made whas the polo??
will it suit luego nose cone??
dimensions?? foto's???
wich year polo?wich engine polo??
TKS
Micael
posted on 28/2/05 at 08:53 AM Reply With Quote
You will need a rad from a 1.0 Polo.
Don't buy the one from a 1.3 as it's sligtly bigger.
You can see on my web that the 1.3 rad wont fit under a GTS-nosecone. After some investigation i manage to get the right rad from Norway as the 1.0 was never sold here in Sweden.
Po lo 1.3 rad
[Edited on 28/2/05 by Micael]
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
DarrenW
posted on 28/2/05 at 11:25 AM Reply With Quote
i was advised to get a polo rad if th epreferred Micra one couldnt be found.
When i say preferred - i mean in the context of fitting into my car. I managed to get a 2nd hand Micra rad so all is well (although very tight fit). Mac#1 are currently putting the polo rad into a pinto engined ZR right now so i know they fit the ZR - should therefore be OK for the Luego.
I have been advised to ditch the std factory fan and fit the largest and powerful (eg) pacet type that i can afford and will fit to assist with those stuck in traffic moments / sunny track days.
