phoenix70
| posted on 22/2/05 at 08:10 PM |
Fuel Injection layout
Here are some question for you guys out there with EFi pinto engines?
I'm trying to figure out all the components I need to get the fuel side of the EFi working. Here is my thoughts, I would be grateful if you
could correct me if I'm wrong. Here goes...
Fuel Tank goes to fuel filter then fuel pump, Fuel pump feed Injector rail that has pressure valve to maintain pressure in the rail and return extra
fuel to fuel tank. I'm sure the haynes manual says there is a pressure regulator between the pump and the injector rail, but I can't see
the point of this.
Thoughts and/or picture much appreciated
Mark Allanson
| posted on 22/2/05 at 08:18 PM |
Exactly right, I have no regulator between the pump and the rail, and neither did my donor, I did put a large filter between the pump and rail though
as per sierra.
CairB
| posted on 23/2/05 at 12:45 PM |
I think that it may be referring to the device that was fitted to the outlet of some pumps to damp out pressure pulses rather than it being a pressure
regulator. There was one of these fitted to the replacement pump that I fitted after to the first one failed due to ingesting a small piece of
plastic. I fitted an inlet filter at the same time and never had any trouble since.
Colin
Mark Allanson
| posted on 23/2/05 at 09:02 PM |
That will be this bit
CairB
| posted on 24/2/05 at 12:46 PM |
That it be.
It was not fitted to my original pump, only the replacement which I removed as there was no room for it. No ill effects noticed.
