Author: Subject: vac advance on distributor
antonyg
posted on 24/2/05 at 07:17 PM Reply With Quote
Hi , just fitted single weber carb on 2.0 ltr pinto engine thers a small hose that goes to vac advance on distributor , problem i've got is my distributor hasn't got vac advance does it need it for the carb to work properly
Any help would be appreciated Thanks
Stu16v
posted on 24/2/05 at 07:24 PM Reply With Quote
Carb will work fine. Just blank the hole/pipe up...
As a matter of interest, what dizzy do you have?
antonyg
posted on 24/2/05 at 08:52 PM Reply With Quote
Not very sure it came with the engine which was fitted with fuel injection unit
i'll try and post a pic of it later
Stu16v
posted on 24/2/05 at 08:53 PM Reply With Quote
Ahh, thats why I asked. Chances are that you are gonna have to replace the dizzy too...
[Edited on 24/2/05 by Stu16v]
antonyg
posted on 24/2/05 at 08:58 PM Reply With Quote
will a dizzy with vac advance and points and condenser fit, reason i ask theres one on ebay at the minute thats in quite good nick
easier to wire up aswell with it having points and condenser
Stu16v
posted on 24/2/05 at 09:12 PM Reply With Quote
If it is out of a Pinto, yep, should drop straight in. Doddle to wire up too. Wire from dizzy goes to negative side of coil. Postive side of coil to ignition live. Fit the HT leads.
Thats it.
HTH Stu.
antonyg
posted on 24/2/05 at 09:17 PM Reply With Quote
well thats that sorted out then
new distributor it is ( more expense )
DarrenW
posted on 25/2/05 at 11:02 AM Reply With Quote
AntonyG
Ive just had similar experience as you. my donor is 2.0 Pinto from injected 1988 Sierra. Dizzy has no vacuum advance but does have a rectangular plug connection on the side. In laymans terms the hall effect needs a signal from the ECU via the amp to make the electronic vac/advance work. Without the crank sensor and injections sensors etc the hall effect doesnt work - i was told it will run fine at full throttle but nowhere else! (ie not much use).
Iam now looking for electronic dizzy and amp from 1.3 or 1.6 pinto, pre'86 2.0 or carb transits. These dizzys have the round vac advance unit (mechanical) and the dizzy plug on a flying lead with 2 wires and round plug. The points type should work fine, easier to fit and you can go for lumenition etc later.
Here is the link to my thread ealier this week where the penny finally dropped for me! In it there is the link to James thread where there are some pics that helped me a lot.
Any questions then dont hesitate to ask again. HTH
Darren.
Stu16v
posted on 25/2/05 at 05:45 PM Reply With Quote
Darren - the link???
James
posted on 25/2/05 at 09:50 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=22738
James
