rich201283
posted on 25/2/05 at 07:10 PM |
zetec 1.8 flywheel or the 1.6
Whats the best flywheel to use on a 1.8 zetec? the 1.8 flywheel or the 1.6 flywheel as i have both
Mix
posted on 27/2/05 at 09:35 AM |
Sorry if this sound flippant, but check the clutch pressure plate locating dowels, they may be different, and use the one that fits your selected
clutch.
Compare weights, the 1.8 flywheel may be lighter in which case this is preferable.
Mick
lsdweb
posted on 27/2/05 at 11:14 AM |
Try the 1.8 CVH flywheel, which can be lightened, much more than the Zetec and is a straight fit. Clutch, starter etc are all perfect fit. The only
complication is that you'll have to use a front crank-mounted sensor, although this is easy enough - I can email pictures if you're
interested.
Wyn
