Danozeman
posted on 28/2/05 at 09:10 PM |
Bike Carbs
Are these any good to run a car engine. Eg zetec??
Ebay link Bike carbs
Dan
billy
posted on 28/2/05 at 09:29 PM |
if your gonna megasquirt the engine id say you want the bike throttle bodies, not the older carbs, cheers
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
big_wasa
posted on 28/2/05 at 09:39 PM |
Yep got me some 40mm from an r1 There's a firm called Bogg Brothers doing well with these.Paid £60 for mine...They are nearly always low millage
...dear bit is going to be the inlet manifold..Bogg Bros above charge £150 ish..You will need a stand alone ignition Im planning on making the
megajolt light jr...
[Edited on 3/3/05 by big_wasa]
Danozeman
posted on 28/2/05 at 10:00 PM |
mmm Just wondering as im after twin 40's thought about these.. Im trying to keep as locost as pos due to being skint..
Im going to run a 2ltr zetec with the esc thing to start for the ign.. So i want easy fueling.
Dan
big_wasa
posted on 1/3/05 at 05:33 PM |
They are ment to be very easy to setup if you Know what your doing and stay tuned ...Ive havent seen webers or the likes for cheap money for a long
time and they are ment to be a bitch to set up correctly ,And if they have been drilled wrong Im told this is hard to reverse????
To give you an idea ,try geting weber/delorto's with less than 12000 from new and guaranteed from a dealer for £60.....
