Author: Subject: Best way to remove a mondeo engine?
rich201283
posted on 1/3/05 at 12:05 PM Reply With Quote
Whats the easiest way to remove a 1.8 zetec from a mondeo
smart51
posted on 1/3/05 at 12:08 PM Reply With Quote
dynamite!
(only kidding)
clbarclay
posted on 1/3/05 at 12:12 PM Reply With Quote
Not sure about mondeo in specific, but the usual way with engine bays is to start by stripping out anything that will come easily.
If you want to do it a little more organised then have plenty of contaiers handy for bitts to go in. Large mushroom punets do very nicely or cake/biscuit tins.
Once the engine is suitably streiped down then useing some form of liftind device (engine crane, over head crane, tele handler) and suitable straps, chains etc. support the engine block, remove the engine mounts and then either drop the engine down or hoist it up out of the car.
Like I said i don't know the specifics of mondeo engine bays but at a guess there is a front subframe that prevents the engine being lowered out.
[Edited on 1/3/05 by clbarclay]
James
posted on 1/3/05 at 12:21 PM Reply With Quote
The more you cut out of the front of the car: slam panel, bumper etc. the easier it is to get the engine out.
Also, label *everything*!!! After a year or two it'll be a real issue to remember the connections. I also don't recomemend pencil on masking tape as it goes faint so you can't read it! Use permanent marker or something.
James
clbarclay
posted on 1/3/05 at 12:33 PM Reply With Quote
The beauty of leaving a stiped engine for a year or 2.
Got several like that kicking about, which I dought will ever see the light of day. Usually because they where striped to find out what went wrong with them and it turned out to be terminal.
clbarclay
posted on 1/3/05 at 12:36 PM Reply With Quote
When disecting the body work of the car take car when cutting that you don't cut anything you will want latter, best left to the last thing before engine hoisting.
shades
posted on 1/3/05 at 12:37 PM Reply With Quote
Sorry for hyjacking but, When its out and lying on the garage floor, What additional bits will be required to make it run in a locost. I am assuming that if you give it air, fuel, water a battery and a RWD gearbox it can be up and running with everything taken from the Mondeo.
I ask the question beacause at the moment I'm baffled by what I need to source in addition: engine management, fuel injection, carbs, ignition pack?
I look in the magazines, and buying the engine/mondeo is easy, but when you start looking at £800 for enginemanagement, £900 for carbs... etc It all gets a bit pricey
Is it possible to use all from the Mondeo?
Any advice?
TPG
posted on 1/3/05 at 01:19 PM Reply With Quote
Any advice?
Type 9 or mt75.All the clutch options are on here with a search.Use either carbs or throttle bodies(I've a set of bike t/b's off ebay for 20notes(!!!) waiting for my next one.Mega jolt or mega squirt(75-500 quid depending which way you go,again do a search on here and google.I was going to use the mondeo engine bits but with prices as low as they are,nearly $2 to the pound it just isn't worth the effort.
..Which was nice..
Bart69
posted on 1/3/05 at 10:51 PM Reply With Quote
depending on your facilitys the easiest way with a ramp is out the bottom including the subframe.
you could drop the car onto a couple of pallets disconnect wiring loom, water pipes, exh, etc and get 6 mates a lift the shell up and roll back
stevebubs
posted on 1/3/05 at 11:17 PM Reply With Quote
Any advice?
Yes - there was a thread on here quite recently on this - someone had detailed how to use all original Mondeo components and get a running engine.
Stephen
