clbarclay
posted on 1/3/05 at 05:53 PM |
Lean on carburettor
What is the maximum amount of forward lean a 2 venturi webber carburettor as fitted to the 1300 x-flow engine?
If the engine is run with the block level will the carb work properly in normal driving or will it only be suitable for hill climbing?
posted on 1/3/05 at 08:16 PM |
Don't worry about it if it's within 5 degrees - once you start accelerating, braking, turning corners, etc it becomes irrelevant!
For info - my engine's level-ish, and the carb leans about 1 or 2 degrees.
