rich201283
posted on 2/3/05 at 07:35 AM |
Do you have to remove the gearbox to get the engine out of a mondeo
Do you have to remove the gearbox to get the engine out of a mondeo?
Is it easier dropping the subframe?
Not sure how you are ment to take these enines out?
andybod
posted on 2/3/05 at 08:29 AM |
lift the gearbox out with the engine then seperate them on the floor it's the easiest way
rich201283
posted on 2/3/05 at 09:03 AM |
Is it easier dropping it out the bottom or bring it out the top
dern
posted on 2/3/05 at 11:19 AM |
I'd consult the haynes manual but the v6 in mine won't come out of the top.
robj
posted on 2/3/05 at 12:22 PM |
removing engine from mondeo
from what i can remember there is not enoughroom to remove the gearbox first, the best way with the mondeo is to drop the front subframe with engine
and gearbox still intact, then strip on the floor, the escorts are far easier to remove the engine.
posted on 2/3/05 at 07:44 PM |
To remove a gearbox from a Mondeo you must remove the subframe. The bolts holding the subframe to the body sometimes sieze in the captive nuts. If
this happens lift carpet from front and chisel out the soundproofing to show a small grill , cut out the grill and use heat and a spanner on captive
nut. At the front mountings slice open chassis above the bolts, use heat again. Probably best to lower engine and gear box as an assembly.
RICK1
posted on 2/3/05 at 08:19 PM |
zetec remove
remove all gearbox mounts leave in driveshafts and it will come out from top just did mine this way last week might after remove the 6 clutch bolts
and prise clutch off through gap once bellhousing bolts are out
Danozeman
posted on 2/3/05 at 10:01 PM |
Unblot the sub frame with engine still attached and drop it out the bottom. Much easier than out the top.
Dan
Bart69
posted on 2/3/05 at 11:57 PM |
couldnt agree more. Thats the way there put in in the factory.
