big_wasa
posted on 4/3/05 at 03:27 PM |
1998 zetec on carbs
Will I get a 1998 zetec to pass emissions if its running carbs and a Kat??????
help needed so I can get my new engine
[Edited on 4/3/05 by big_wasa]
zetec
posted on 4/3/05 at 05:35 PM |
It is poss to do but you will need to buy a cat designed to run with carbs and use a setup with an air bleed system, it can be done but not easy. I
think the cat would have to be removed and replaced for each MOT as they don't last long on carbs due to the poor fuel/air metering.Your best
bet is to do it properly with injection, or get a pre"95 engine.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
big_wasa
posted on 6/3/05 at 08:56 AM |
Thanks for the reply but whats an air bleed system involve,
The cat replacment is not a prob as if its anything like my bike it will only see 500 miles a year..And the kat's a bit like the standard
exhaust can on the bike ,It will only see 1 day use a year
zetec
posted on 6/3/05 at 09:54 AM |
As far as i know the air bleed uses small bore platic tube with a fish tank valve to bleed air into a hole drilled into the carb throat. Opening the
valve will allow more air to weaken the mixture and drop the emissions, a bit hit and miss thought!
might be worth a post on BEC section if no other responses.
