clbarclay
posted on 6/3/05 at 05:16 PM |
Engine mounts
page 171 of Ron Champions second edition book shows a good alternative engine mount to others in the book.
The type with a tube running from the block starigth down to a rubber block between tubes F and G.
What are people using for the rubber block though?
Will scafold pipe do for the main tube?
theconrodkid
posted on 6/3/05 at 05:21 PM |
cortina/land rover mounts,scafold tube is horribe to work with and weld,1" dia is strong enuf
who cares who wins
pass the pork pies
posted on 6/3/05 at 05:48 PM |
I made mine from some 40x3mm rhs I found at the scrapyard. Any bigger and I don't think the bolts would have gone past then at the block end.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=left_mount.jpg
NS Dev
posted on 6/3/05 at 06:01 PM |
That's basically the type of mount that I have used. I made mine from 1 1/4" CDS as I had a bit laying about after making the frame on my
grasser. I made plates for the engine end, cut the ends of the tube to the suitable angles, and then at the "mount end", scalloped the end
of the 1 1/4" tubing and welded it to a short length of 1 3/4" CDS, cut flat at the bottom and at an angle at the top to match the angle
of the smaller tube. I then used a holesaw to make "washers" which I welded to the base of the bigger tube and the holes in the centre of
these go over the threads of the mount rubbers.
sounds complicated cos I am crap at explaining, will get a pic tomorrow, camera batteries flat now!!
chriscook
posted on 6/3/05 at 06:41 PM |
I'm using type-b buffers from here:
http://www.gmt.gb.com/gmt-productrange.html
907
posted on 6/3/05 at 07:01 PM |
Rubber blocks ?
These are from a Metro
75 mm dia x 55 mm thick.
hth
Paul G
