Steve Hnz
posted on 8/3/05 at 04:33 AM |
Are these wheels anygood?
Any comments as to the suitability or otherwise of these wheels for a locost build using Cortina Uprights & Sierra back end 14x5.5" about
ET38, suposedly from a Sierra sapphire? Thanks, Steve
[Edited on 8/3/05 by Steve Hnz]
![](/galpreviews/a189176-Ford4x4alloys.jpg) ![Rescued attachment Ford4x4alloys.jpg](/gallery/a189176-Ford4x4alloys.jpg) Rescued attachment Ford4x4alloys.jpg
SeaBass
posted on 8/3/05 at 08:11 AM |
You'll need spacers on the front... about 3/4" (19mm) according to my calculations. The Cortina wheels are approx ET19 + 19 this gives the
ET38. This is not as bad as it sounds tho as the bearing load should remain constant. If you imagine you haven't moved the rim in the wheel
changeover just filled the gap that would be there otherwise. Hope this explains. I've done the same to run my FWD wheels.. Not had any probs so
far. Oh and you'll need longer studs. Got all mine from a Grayston Engineering stockist.
http://www.graystonengineering.com/front%20page.htm
NS Dev
posted on 8/3/05 at 08:49 AM |
Yep, ok to use, but follow Seabass's advice, as these are XR4x4 Sierra wheels ane have the "4wd offset" which is as (or similar) to
the front drive Ford offset.
RogerM
posted on 8/3/05 at 05:56 PM |
A better way forward would be to extend the front wishbones by the amount required. Longer wishbones are always of benifit.
Obviously you would need to move the top shock point out by the same amount.
Using ET38s on my car, always have.
Mark Allanson
posted on 8/3/05 at 06:56 PM |
It is the design of the cortina upright which needs the 19mm offset, not the necessity to keep a constant track. If you use ET38 on the cortina
hubs, the loading on the wheel bearings will be 19mm inset of the load path.
posted on 8/3/05 at 07:22 PM |
Factory Cortina Mk3-5 Rostyle wheels were a different offset from other Ford rostyles. Put one Capri rostyle on the front of a Cortina and you would
get a massive steering pull towards the Capri wheel when braking. First time I encountered it it took me hours to twigg as the wheel were almost
identical in appearance but the back space was different by 0.5"
Stu16v
posted on 8/3/05 at 07:47 PM |
The bearings are very unlikely to give issue, the main reason being there is far less weight in a locost to begin with. Britishtrident has hit on it -
scrub radius. This affects steering feel and feedback, as well as how the steering will react with a puncture on the steered axle.
Interestingly, most modern Westfields use Cortina uprights and 35+mm offsets...
gazza285
posted on 8/3/05 at 08:30 PM |
No, they are horrible.
Stu16v
posted on 8/3/05 at 09:41 PM |
...in your opinion of course....
Steve Hnz
posted on 9/3/05 at 06:38 PM |
Having measured some 5 1/2" Mk 3-5 Cortina wheels, both sculpted ( Rostyle) & plain steel,I can confidently say that the ones I measured
were ET38, the same as the 5 1/2 x 13" steel Sierra wheels I have & as such I would be surprised if there was a problem with the front
geometry because of this. I guess I was after objective comments re weight & suchlike, much as I would like a set of superlites/miniltes,
these xr4x4 wheels are about 1/4 the price of them & I also think they look quite sharp. Gazza285, care to expand on your comment?![](/images//smilies/bigsmile.gif)
Cheers & thanks for the input, Steve.
gazza285
posted on 9/3/05 at 07:29 PM |
Just being my usual facetious self. Not the most attractive wheel Ford have made.
Liam
posted on 9/3/05 at 10:44 PM |
I agree with Stu. Bearings wont be a problem at all (in fact in this case moving the wheel in 19mm probably moves the centre of the wheel closer to
the bearings and reduces bending loads on the stub axle and stress on the bearings) and any reduction on the huuuuuuge scrub radius that
cortina uprights give is welcome. Probably why westfields use et38s on cortina uprights.
Oh and the wheels are lovely - wanna buy a spare set of 5 off me for a tenner?
Liam
Steve Hnz
posted on 10/3/05 at 03:09 AM |
Liam, I'd love to but I think the shipping might kill the deal somewhat.
Gazza, I probably asked for it anyway, not a very well phrased query in the first case, but seriously, I think they look OK, Not as good as superlites
etc but hey, its 'sposed to be locost & seriuosly, Ford have made worse I reckon by a long shot. I guess beauty is in the eye of the
beholder, just as well for fat ugly women![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
NS Dev
posted on 10/3/05 at 12:59 PM |
I like to look of them too!!
They are nice and subtle, not like some of the crap wheels that a lot of manufacturers were fitting in the 80's!!!
I';m biased as I am an XR4x4 fan and have one as a daily driver I suppose, but I certainly wouldn't stick any other wheels on it for
aesthetic reasons!!!
blueshift
posted on 10/3/05 at 01:07 PM |
I have the same wheels and am planning to use them on the locost. nice that they're fairly light alloys and if it's a set of rims or a
nice paint job I know where the money's going.
