Author: Subject: Fuel Pump
timwest167
posted on 9/3/05 at 03:15 PM Reply With Quote
Fuel Pump
What fuel pump would you recommend for a 2l zetec with weber 45s? The engine is standard, though if I can afford it I may tune it once the car is finished... well as finished as kitcars ever are!
I expect the power will be about 150 - 160bhp. Will a Facet solid state be OK, or should I go for the pricier red top?
Presume I'll need a regulator and filter such as a FilterKing after the pump. Probably a good idea to filter between the pump and the tank as well?
Tim
givemethebighammer
posted on 9/3/05 at 05:10 PM Reply With Quote
I use the fast road version of the facet solid state with a malpassi fuel regulator. Works for me
Rally Design sell all versions (std, fast road and race) of this pump.
http://www.rallydesign.co.uk/catalog/advanced_search_result.php?keywords=facet&osCsid=a49e06fd07967641e7a69ff669a419f9
