Author: Subject: Does the standard t3 escort manifold bolt on the zetec?
rich201283
posted on 10/3/05 at 01:37 PM Reply With Quote
If not what is the best manifold and turbo to use?
Or do you just modify the manifold
garage19
posted on 10/3/05 at 04:45 PM Reply With Quote
It does fit on but you have to re drill and tap the head to re locate the studs.
The ports do all line up though.
Ther may be some photos of mine in my album.
Doug.
zetec
posted on 10/3/05 at 07:47 PM Reply With Quote
I have been looking into this. The flange will not fit without moving the stud fixings. ..So why not cut the flange off the manifold and weld on a zetec one? You can get them ready cut for making up custom exhausts, is the problem welding the cast manifold to a steel flange?
garage19
posted on 11/3/05 at 08:39 AM Reply With Quote
That is the problem indeed. Welding to cast iron is very tricky apparently!
I drilled and tapped the head with out too much problem.
This method has been used quite a bit in the boy racer RS turbo world.
I am also gonna use a home built turbo damper that supports some of the turbo weight as most people run on a cossie. Stops manifolds cracking and studs being pulled out of the head.
