Author: Subject: zetec fuelling
Dillinger1977
posted on 12/3/05 at 05:50 PM Reply With Quote
zetec fuelling
im considering a part finished project, which has a 2.0 zetec (unsure as to what exact model it is so far)
apparently it hasnt got an induction system, so needs either carbs or throttle bodies.
ive noticed theres a couple of complete kits available, and there doesnt seem to be much between them price wise.
anyone any recommendations in this area?
thanks
(edit) alpha seem to do a 'Gold' throttle body kit for 895 without vat. that sound about right?
http://www.webcon.co.uk/alpha/AlphaPlusKits.htm
[Edited on 12/3/05 by Dillinger1977]
stevebubs
posted on 12/3/05 at 07:10 PM Reply With Quote
Originally posted by Dillinger1977
thanks
The £895 kit is to re-use the factory throttle body system (i.e. you need the donor's injection system.)
If you haven't got an induction system, the full kit is £1650.
If you're looking for a budget install, get hold of a pair of twin DCOES - 40's or 45's, manifold and an ESC2 ignition module out of an older car.
Big Stu
posted on 12/3/05 at 08:55 PM Reply With Quote
I have got a brand new factory induction kit, including jets, fuel rail throttle body. Never used, could be used with the kit. Pay for the postage and a few pints and it's yours.
Like steve says the easiest and cheapest option is for the webers, thats the route I went but I used a weber alpha 2D ignition.
Danozeman
posted on 13/3/05 at 10:42 AM Reply With Quote
Im going to use bike carbs on my 1.8 zetec. Much cheaper than twin 40's etc. The only problem is you need to make up a manifold for them which shouldnt be to hard.. For the ign im going to use the esc unit from escorts although i will upgrade to alpha or summit when money allows unless it performs well in which case i wont bother.
Dan
