Author: Subject: Zetec Cooling... Oh no! not again!
Micael
posted on 15/3/05 at 08:56 AM Reply With Quote
I have looked at the plumbing drawings at Zetec-cat and I was thinking if I could smplify the plumbing a bit. Here is what I came up with. Would this work? Rescued attachment cooling-system-simp1.jpg
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
Lozec
posted on 16/3/05 at 03:53 PM Reply With Quote
Come on guys, someone must have tried this and know if it'll do the job!
zetec
posted on 16/3/05 at 10:30 PM Reply With Quote
Almost there. The large thermo housing outlet is as per the diagram to the rad top hose. The two other mid size ones to join into the bottom hose between the rad and water pump. The expansion tank is teed into the offside mid size pipe on its route to the bottom hose connection. The small outlet to the exp tank small neck connector.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
