phoenix70
| posted on 19/3/05 at 10:41 PM |
Radiator Mounting
Hi All,
Just wondered if anyone has got any piccy's of the mounting brackets for the radiator. I'm trying to mount my Micra Rad to my Indy
chassis.
Anyone got any advice on the positioning of the radiator?
TIA
Scott
| posted on 19/3/05 at 10:56 PM |
Some in our rebuild diary
CLICK ME, CLICK ME!!!
Any more details you need I'll be happy to give!
[Edited on 20-3-05 by Hellfire]
| posted on 20/3/05 at 04:49 PM |
Hellfire - I'm just trying to do the same job and it's driving me potty
Looking at your pic and on your website I see your top mounting brackets are bolted to some metal brackets on the top corners of the rad. Are these
brakets part of the rad or did you make them? How do they attach to the rad?
Also looking at your bottom right mount (looking from the front of the car), you've used the plastic 'pin' on the rad body to attach
to your mount. Have you done the same on the bottom left? My Micra rad doesn't have a lug on that side!
Any more photos would be much appreciated
Also, I assume you have ditched the Micra's expansion tank and used a seperate one?
Nick
PS - once I get the rad sorted I'm ready to try and get the engine running
Mark Allanson
| posted on 20/3/05 at 08:18 PM |
Not an MK, but a book chassis
Mark Allanson
| posted on 20/3/05 at 08:19 PM |
I used the existing rad mounts (height offset) and rubbers
James
| posted on 20/3/05 at 08:59 PM |
Me too.
Until that is... I couldn't get it into Ned's GTS nosecone so cut off the upper off-side mount and just did it to the small plastic one
there.
HTH,
James
- Muhammad Ali
