harvey115
posted on 6/4/05 at 07:23 PM |
what fuel pump do i use
can anybody help, i need to know what sort of fuel pump i use on my MK indy, im using their tank an im running it on a 2.0litre zetec on bike carbs
also what do i do with the outlet on top do i drill a hole if so what size?
Surrey Dave
| posted on 6/4/05 at 07:57 PM |
Some may say use a bike fuel pump, i've use a Facet solid state fast road fuel pump with a FilterKing/Malpassi fuel regulator set to 2lbs (this
pressure may vary with your carbs)
Kitlooney1000
| posted on 6/4/05 at 08:11 PM |
Sorry to hijack this thread,
Dave, How do you measure the pressure that you set the filter king to?
I have just installed one and not adjusted, certainly not measured it.
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
Surrey Dave
| posted on 6/4/05 at 09:05 PM |
You can use a fuel pressure gauge ,or you can measure the amount height the fuel will pump up a tube 'head of fuel'.
1 psi of water would = roughly 27.7" of head
1 psi of petrol is roughly 39" of head ,therefore the pump and regulator should pump fuel up to 78" for 2 psi.
What I actually did was use a cheap fuel pump gauge but calibrated it first with 55.4" of water in tube.
All those programmes like 'Blue Peter' and 'How' were not wasted on me!!!!
Kissy
| posted on 7/4/05 at 12:59 PM |
Go for the bike pump! See this recent posting:
http://locostbuilders.co.uk/viewthread.php?tid=24230
