RogerM
| posted on 9/4/05 at 04:46 PM |
Granada diffs instead of Sierra units
For those of you using hi reving car derived engines you will be looking for a lower axle ratio than is easily available from the Sierra range. The
Scorpio shaped Ganarda can help you out.
This chart may be of use ....
http://www.fordscorpio.co.uk/mt75.htm
RogerM
| posted on 9/4/05 at 05:03 PM |
This might be better, the other site link might not work for you all....
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Granny%20diff%20ratios.JPG
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=grannyvin.gif
phelpsa
| posted on 9/4/05 at 08:58 PM |
They are very heavy though!
[Edited on 9-4-05 by phelpsa]
RogerM
| posted on 9/4/05 at 09:04 PM |
Not really that much more than a Sierra one.
Lighter than a Scooby one I think... and easier to fit as it bolts up where the Sierra one did.
phelpsa
| posted on 9/4/05 at 10:41 PM |
According to http://www.dpcars.net the scooby one is lighter than the sierra ones.
Adam
ned
| posted on 9/4/05 at 10:47 PM |
presumably these are the 7.5" difs? so wouldn't fit a car already built to use a 7" dif without severe modification of diff
mounts?!
Ned.
beware, I've got yellow skin
Mark Allanson
| posted on 9/4/05 at 10:48 PM |
I fitted a new rear subframe to a Freeloader recently, I could hold the axle and subframe in place with one arm while tightening the bolts with the
other. A gem of a diff, the driveshafts look really light as well
RogerM
| posted on 9/4/05 at 11:08 PM |
Ok, if you say so .... have 2 Sierra difs here and 2 Granny ones, either or bolt straight up to the mounts I've made, must admit to there being
no height problems in my design.
Freelander difs are light, not sure what ratios are available though. Know they can be suited to BEC but what about CEC???
