Author: Subject: luego throttle cable and pedal
the moa 2
posted on 10/4/05 at 05:25 PM Reply With Quote
luego accelarator cable and accelator pedal
Well thought i do something simple today but no nothings simple is it !
I have a 1.6 pinto fitted in my luego locost i bought the pedals from luego and the cables and i am trying to fit the accelator pedal .
The cable is labelled up as being a peugeot citroen and renault cable various cars from twingo to clio , so the instructions are useless and luego haven't any with there build manually and being that im not to cleaver im a bit stumped.
Can anyone help please !
posted on 10/4/05 at 07:58 PM Reply With Quote
Citroen Peugeot cables usually come as a kit to be assembled as needed, throttle pedal top end may need to be slotted to allow top end of cable to be connected? mine did. Route outer cable as needed ,cut to length , thread through inner cable , fit nipple at carb/throttle spindle end and cut off excess
the moa 2
posted on 11/4/05 at 06:41 PM Reply With Quote
Hi thanks for replying if possible would you be able to get a pic cause were a bit stupid and just cant work this out !
we have half of the cable that was connected on the carb side but it does look like we can take of the bit that clips on to the carb so is it possible to connect these two cables together somehow? & is that the niple bit you were talking about ?
Once again thanks rusty
posted on 11/4/05 at 08:00 PM Reply With Quote
Was the cable you have supplied as a kit of parts? if so the nipple is the part with the screw through it to clamp to the inner cable
the moa 2
posted on 11/4/05 at 10:31 PM Reply With Quote
Yes the cable came as a kit of parts from luego.
It came in a plastic bag with a set of paper instructions labeled "Kit Accelerator cables" and shows diagrams of how to put the parts together for the different cars ie peugeot 104-samba-205-309-305... etc
The kit consists of the following:
1. Metal cable with a metal blob or tab at one end.
2. plastic outer cable sleeve
3. spring about 14mm in diamtere and 50mm long
4. brass cable sleeve about 70mm long
5. metal cable end peice about 60mm long (looks like it could be crimped onto the end of the cable)
6. 4 various plastic bits (hard to describe them all)
7. 4 Various rubber bits
8. One confused/stupid kit car builder !
the moa 2
posted on 16/4/05 at 11:31 AM Reply With Quote
Hi has anyone any thoughts i dont want to bodge it especially when it came with the luego kit so surely there must be a standard set up?
