Author: Subject: fuel lines
hector
posted on 14/4/05 at 09:32 PM Reply With Quote
fuel lines
Is it ok to fit copper fuel supply/return lines (10mm OD) and will it be sva compliant?
shortie
posted on 14/4/05 at 10:10 PM Reply With Quote
Well I've used exactly that down my tunnel, should be fine for SVA.
Rich.
tri
posted on 14/4/05 at 10:12 PM Reply With Quote
if its not i am stuffed
Tri
[Edited on 14/4/05 by tri]
wilkingj
posted on 14/4/05 at 10:36 PM Reply With Quote
And Me, Ive used 8mm centrqal heating pipe. however, I have encased it in split convuluted tube, the stuff I am also using to cover the wiring.
DONT run your electrics / wiring next to the fuel lines. SVA fail.
Brakes and wiring is OK, but not fuel and electrics.
Best Regards
Geoff
http://www.v8viento.co.uk
tri
posted on 14/4/05 at 10:38 PM Reply With Quote
by together do you mean touching or do you mean with in sertain distance?????
Tri
shortie
posted on 15/4/05 at 10:31 AM Reply With Quote
Basically don't run them the same side of the tunnel next to each other, one at the top and one at the bottom would be ok.
Rich.
[Edited on 15/4/05 by shortie]
locoboy
posted on 15/4/05 at 11:03 AM Reply With Quote
preferably electrics at the top and fuel at the bottom though!
Locoboy
hector
posted on 15/4/05 at 05:06 PM Reply With Quote
splend, thats good enough for me then, b & q here i come!, thanks for all your help
cheers colin
