Jeffers_S13
posted on 15/4/05 at 08:44 AM |
Oil pick up pipe
Can people post pics of their modified pick up pipes please ? so I can form an idea for the design of mine.
To describe what I have, the pipe starts as a bend abou 1.5" radius heading down down from a bolted flanged connection to the oil pump and
turning towards the middle of the sump, runs straight for about 4" then it would normally bend down again I have cut it flush across the bend
and in line with the bottom surface of the straight run (if you see what I mean) the final oval shaped hole is parallel with the bottom of the sump
and is about 8mm from touching.
I need to put a gauze on it somehow, is anyone elses anything like mine ? if so how have you fitted a gauze ?
James
posted on 15/4/05 at 09:26 AM |
I have a pic on my build site here www.winchester7.com have a look in the Feb 2004 section for pics of the
modified sump and pick up pipe
HTH
Nick
Jeffers_S13
posted on 15/4/05 at 10:34 AM |
Is that the Pinto from the Sierra you are using ?
Looks like I could adapt an oil pickup gauze from one to fit mine.
James
posted on 15/4/05 at 10:45 AM |
tis' indeed the mighty Pinto, donated froma Sierra.
Having looked at your archive more closely, it looks like you are using a Zetec?
The principle should be the same though!
Nick
bob
posted on 15/4/05 at 11:05 AM |
SUMP AND PICK UP
There are some good sites in the links section,this is one of them that i have used.
http://www.zetec-cat.co.uk/
click on fitment and its all there
Jeffers_S13
posted on 15/4/05 at 11:15 AM |
Nick
No...guess again !
'Can you tell what it is yet ?' (in a Rolf Harris stylee)
BIG ! clue in the pic I just uploaded called Engine mock up
Jeffers_S13
posted on 15/4/05 at 11:38 AM |
That Zetec link was perfect, I think Ill get a Zetec oil gauze thing now, that is almost identical to how mine will have to be.
James
posted on 15/4/05 at 12:14 PM |
ahhh! All becomes clear
bob
posted on 15/4/05 at 01:56 PM |
I didnt even look in the archive,looks a nice fitment
Jeffers_S13
posted on 18/4/05 at 08:37 AM |
Do all Zetec varaints have the same style pick up pipe ?
Anyone know of any Zetec specialists that could do me a good deal on one ?!
Not sure if a scrappie would be too keen on letting me pilfer a pickup pipe off an otherwise potentially good engine, not very often they get in cars
with duff engines.
James
