scutter
posted on 19/11/02 at 09:38 AM |
head gaskets
Greeting all, been a while but now back in the country(missed exeter by one day bugger)
Headgasket question for all you folks with 1700 X-flows.
The company that did my re-bore says that a standard head gasket with fit(eng bored out +.090") is this true?
I can't measure the old gasket as i threw it away in a rash moment of tidying up(should never happen i know)
All help greatly recieved cheers
Dan
kingr
posted on 19/11/02 at 11:22 AM |
Looking in the Burton Power catalogue, they sell regular gaskets, and then also gaskets for upto : 83.2, 83.3, 84 and 87.5, so I'm guessing it would
be wise to use one of the larger ones, which one, I don't know though without doing the sums, and I'll leave that to you
Kingr
bob
posted on 19/11/02 at 12:24 PM |
Hello Dan
Give vulcan engines a bell i'm sure they would know
http://www.vulcanengines.com/
locodude
posted on 19/11/02 at 07:06 PM |
Hi Scutter my pink tented friend!
The max oversize for x-flow is +90 so it SHOULD be ok. But no engine tuner I know of uses a std gasket as the fire ring is a little too close to the
bore edge for comfort and tends to errode. I would use a Felpro from Burtons or a Reinz from Vulcan. If you look at either of these against a
replacement set you'll see the difference in quality. Last time I used a Reinz from Vulcan, about £16+vat I think. No probs so far. If you want a
reuseable one go for a steel cometic one from Vulcan. £90 though!!!
scutter
posted on 19/11/02 at 07:33 PM |
hello my friend with the new bedraggled hair cut.(very fetching)
Thanks for the advice the vulcan price sounds quite good,(was only asking because i was put off by the price burton were asking)
will give them a call in the morning.
hope all's well up north.
Take care Dan.
