Author: Subject: Land Rover engine mounts ?
UncleFista
posted on 18/4/05 at 01:38 PM Reply With Quote
Hi all, need to drop my crossflow an inch or two and I'd rather not butcher my welded-to-the-chassis then powdercoated brackets
Best idea I think is to reduce the rubber (stock) mounts from 3cm to 2-ish, does anyone have a land rover mount handy to measure the thickness ? Or a suggestion for a rubber mount less than 3cm ?
Thanks in advance
Tony Bond / UncleFista
garage19
posted on 18/4/05 at 01:50 PM Reply With Quote
landrover square v8 mounts = 36mm
UncleFista
posted on 18/4/05 at 04:20 PM Reply With Quote
bugger ;(
If I can't find any thinner than that, it might be "plan B" butcher the steel mounts themselves....
Cheers for the help
