grusks
posted on 18/4/05 at 10:15 PM |
Zetec Bike Carbs
Rebuilding my 2L zetec at the mo, and thinking about fuel etc.
Im looking into bike carb setup, but aint got a clue what bikes carbs im looking for.
900 or 600 or R1 or what year or choke size.
Any pointer please.
Need More Money
stevebubs
posted on 18/4/05 at 10:45 PM |
Any pointer please.
anything around 40-45mm should do, so long as you can re-jet them.
Probably worth talking to one of the specialists as to the best ones to get.
big_wasa
posted on 18/4/05 at 10:46 PM |
The bigger the beter
Im told that anything over 38mm is recomended on the 2l...I have two sets the first .R1's at 40mm the second is a set of Blackbird's at
42mm........
There are a few pics in my archive of the R1's on the zetec...............
grusks
posted on 19/4/05 at 06:34 PM |
Mr Wasa. I keep looking at your arcive and then looking at my credit card.
Top looking set mate. Where did you get the manifold from ?
Need More Money
big_wasa
posted on 19/4/05 at 07:58 PM |
Yep not exactly locost but Im fairly pleased with it...............
Bogg Bro's 01944 738234 did the work
Well recomended ,its the best service ive had from a firm in a long while(well Burton power was v-good aswell) The guy you want is Stephen.........
Top tip is sort the filter your self as its the dear bit......Must be a locost way
The bargain was the jetting work...The manifold is ok,welding work being very good Stud spacing could have been done with a touch more care...But all
in all a top job........
Having got both I think the honda carbs are better quality and the ones I have are much better condition......
A mint set of quad 42's for £50
They are for my next project.........
big_wasa
posted on 19/4/05 at 08:16 PM |
honda cbr 1100xx carbs(blackbird)
big_wasa
posted on 19/4/05 at 08:19 PM |
getting there
grusks
posted on 19/4/05 at 10:09 PM |
Did burtons make a manifold as well, just that i've known the guys at burton personally for years (mod prod racing days), i might have
to see if they want to make one for me on the cheap.
Need More Money
big_wasa
posted on 20/4/05 at 06:20 PM |
No I got all my parts to rebuild the zetec from them.......Bearings to rings the whole lot...I said that I had got good service as there was an oil
controle ring missing (strange as no-one ever breaks them) and they where changed with out to much fuss.......
Bogg Bros did all the inlet work....I sent them a set of carbs in the post and the whole lott returnrd ready (well almost)to bolt on and
run...............They did all this in about a week... A lot quicker than outher places ive used in the past/present.. They custom made the manifold
to suit the carbs/cleaned and rejeted the carbs/cut the airfilter back plate to fit and bonded it direct to the carbs and then fitted the carbs to the
manifold ....
Ianz18avon
posted on 21/4/05 at 09:49 PM |
Thanks for the photos I ordered my carbs Tuesday from Steve (Bogg Brothers.
violentblue
posted on 20/4/07 at 02:10 PM |
getting there
do you need to cut a hole to clear those carbs?
a few pics of my other projects
bob
posted on 20/4/07 at 07:58 PM |
I'm going to have to cut a hole in the bonnet for the air filter on my fireblade carbs on the zetec, more work from bogg bros here.
violentblue
posted on 20/4/07 at 08:36 PM |
i'd really like mine to be below the hood, do they have to be mounted at that angle? if you could tip them down a bit it'd help some
bob
posted on 20/4/07 at 10:24 PM |
my filter is pretty deep but it is possible to fit a shallower one,not sure if top of the foam filter is advisable so close to the trumpets though.
I'm sure advice will follow
se7ensport
posted on 20/4/07 at 11:30 PM |
The manifold needs to be at an angle due to carb float bowl otherwise you increase the risk of surge under cornering etc...
