Author: Subject: Pinto Cambelt
andyharding
posted on 23/4/05 at 12:29 PM Reply With Quote
Pinto Cambelt
Hi Guys
I want to change the cambelt on my 1600 LS Pinto but I don't have the Ford tensioning tool.
Do I need to buy one or is the Haynes twist method good enough?
Cheers.
swood
posted on 23/4/05 at 12:40 PM Reply With Quote
Pinto Cambelt Tension
Use Haynes method, Correct Tension is important but not as crucial as some engines because If belt breaks on a Pinto it does not lunch itself - (valves do not hit pistons)
When you're up to your ass in alligators you tend to forget the initial objective was to drain the swamp !.
andy d (rizla)
posted on 23/4/05 at 12:45 PM Reply With Quote
i thought the 1600 hits but the 2000 misses due to having a taller head?
Fifer
posted on 23/4/05 at 01:43 PM Reply With Quote
Twisting method is ok, I have fitted loads and used this method.
If pulleys are in good nick and genuine manufacturers belt is fitted, you will have no problems.
andyharding
posted on 23/4/05 at 04:04 PM Reply With Quote
Thanks for the info.
It is the long stroke 1.6 i.e. 165 block. The stroke is the same as the 2.0.
andy d (rizla)
posted on 23/4/05 at 04:58 PM Reply With Quote
it dont matter itsz to do with the head
DrEagle
posted on 23/4/05 at 06:21 PM Reply With Quote
I just didmine by hand, Also check the bearings in the tensioner.
Never be afraid to try something new!
Remember that a lone amateur built the Ark with no budget,
where as a large group of professionals spent millions building the Titanic!
