steve m
posted on 23/4/05 at 02:55 PM |
cleaning engine valves
how do i clean engine valves that have burnt carbon/c**p on them ?
steve
posted on 23/4/05 at 03:18 PM |
I spun mine in my lathe, using emery cloth to clean them.
This is not much help if you haven't got a lathe!
Surrey Dave
posted on 23/4/05 at 03:24 PM |
Spin 'em in an electric drill , use emery or wet n dry , but not on the seat area !
Or you can chip away with a knife and finish them off on a wire wheel....
The Phantom Bodger.............
gazza285
posted on 23/4/05 at 03:27 PM |
Not with your finger I hope David, but with it nailed to a piece of wood?
Danozeman
posted on 23/4/05 at 04:14 PM |
Put em in a drill and spin em with some emery cloth. If they are a bit sticky spray em with WD to soften it up.
I usually clamp the drill in a vice to make it easier.
Dan
posted on 23/4/05 at 06:17 PM |
Why would I want to nail my finger to a piece of wood!
No, I used a thin strip of emery cloth held lightly between my fingertips - fully prepared for any snagging or tangling whipping the cloth out of my
fingers.
posted on 23/4/05 at 07:07 PM |
If you have one use an old valve as a chipping hammer , chip off the worst of the carbon, then if you have access to one use a bench grinder with a
wire wheel to clean off the rest. If you haven't got a bench grinder try paint stripper or gasket stripper , excellent at removing carbon from
heads and valves
steve m
posted on 23/4/05 at 09:11 PM |
paint stripper
someone has a good answer !!
"put them in a drill"
i did things like that when i was 15 !!
NS Dev
posted on 24/4/05 at 07:34 AM |
nowt wrong with putting them in a drill, does the job fine. People have been known to make very effective wasted stem valves like this! (needs
considerable care though!)
