Ronin
posted on 2/5/05 at 08:05 PM |
1300 Crossflow Problems
The crossflow in my Gemini was running too rich, even after adjusting the mixture to as lean as possible. I added a Filter King pressure regulator
which seemed to help. The only thing is when I took the car out on a local private road (No SVA yet) it was fine until I reached about 3000rpm in 3rd
gear. It then began to act as if miss firing or suffering from fuel starvation. I don't have this problem in 1st or 2nd. Any suggestions as I am
completely stumped?
Marcus
posted on 2/5/05 at 08:17 PM |
What ignition system are you running? If it's good old points, check the condenser, they seem to break down under load. Once had a car ran
perfectly up to 2000 revs, then misfired like a good 'un - went through the fuel system, all seemed ok, changed ALL ignition parts, went like
stink so I swapped parts back one by one, Condenser was at fault.
Marcus
Marcus
Because kits are for girls!!
Ronin
posted on 5/5/05 at 06:36 PM |
Cheers Marcus, will give it a go. Fuel system all seems to be fine now so it must be the ignition.
