short track 123
posted on 4/5/05 at 08:28 PM |
Zetec and bike carbs
Hello all
I,ve seen some people fitting bike carbs on zetec ( 2Lt , 1.8 , 1.6 ) engines does anybody know what sort of power you could get and with what sort of
engine spec?
big_wasa
posted on 6/5/05 at 09:30 PM |
Im told that power is same (ish) to twin 45's ie 165bhp for 2l 155 for the 1.8l(130 spec cams) and dont bother with the 1.6.
The bike carbs come into there own ,with the drivability ie very good response across all the rev range...still building the motor so I have not
driven mine yet
Danozeman
posted on 6/5/05 at 09:56 PM |
As wasa said plus bike carbs are cheaper than twin 40's etc.
Ive been told 165bhp on my 1.8 when set up right.
Dan
short track 123
posted on 7/5/05 at 04:08 AM |
Thanks for the info guys
Do you use trumpets on under the air fillter if so what O/D and length are they?
Thanks again
Jason
zetec
posted on 7/5/05 at 07:01 AM |
The zetec benifits with a long intake system. With throttle bodies which are about the same length as Webers the best trumpets are 4-5" long.
The only snag is that they end up sticking out the bonnet of a "7" by 2"-3".
Jenvey quoted that on highly tuned engines the difference between long and short intakes could be 30-40BHP!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
