Author: Subject: de dion diff drawings
speedys2k
posted on 10/5/05 at 02:16 PM Reply With Quote
Hi all
I have just started buidling a honda s2000
engined locost and I am planning on using a di deon diff and I was wondering if anyone had any pictures or drawings of a de dion setup or info on honda engined locosts.
James
posted on 10/5/05 at 02:55 PM Reply With Quote
I wish!
I don't know of anyone with a S2K engine in a Locost- although Atomic on here has fitted one to his Quantum Extreme.
Why are you after pictures of a De Dion? I thought you were going to buy it from Darren (GTS)?
Welcome to the site by the way.
James
[Edited on 10/5/05 by James]
Stu16v
posted on 10/5/05 at 09:42 PM Reply With Quote
The diff used with most dedion axles is the good old Sierra jobbie...
Mr G
posted on 11/5/05 at 10:33 AM Reply With Quote
You won't find many traditional rwd cars using Honda engines (ones that originally had a transverse application anyway) because they rotate the other way than standard which would be ok if you wanted 1 forward gear and 5 reverse
Obviously the s2000 lump/box will be diferent because of its rwd configeration.
THIS will probably be of some use.
HTH
G
[Edited on 11/5/05 by Mr G]
