CHIEF
posted on 13/5/05 at 01:03 PM |
X-Flow problem!
Hello all,
I have a newly aquiered 711M crossflow with standard carb, kent cams, new head and pistons.
Its drive fine-but when under full load and I hit about 3500rpm there is a jolt in the power for a split second and then power is resumed!
Any ideas with what to fiddle with? I still in the learning stage with this engine/all carb engines!
Thanks in advance
GazzaP
posted on 13/5/05 at 01:28 PM |
Hi
I had this with my 1300cc x flow and it ended up getting setup on the rolling road and re jetted.
gary
phil m
posted on 13/5/05 at 05:13 PM |
as above ---rolling roaded ('cause I wanted to) the carb needing rejetting and had lots of wear. Found out that the distributor needed renewing
aswell and the timing was adjusted to suit the current situation--------
Result= smoother running, with ironed out flat spots
CHIEF
posted on 16/5/05 at 07:17 AM |
Cheers guys! Looks like I will have to pay for some rolling road time then
Will driving it like it is at the moment damage the engine?
[Edited on 16/5/05 by CHIEF]
posted on 16/5/05 at 05:23 PM |
Sounds like you may have a weak mixture if so this could cause a melted piston . Get it sorted and car would be much nicer to drive and probably more
economical/reliable
