spud u like
posted on 15/5/05 at 09:23 PM |
fuel pipes
i am using a nylon fuel pipe would it be okay to use 10mm copper pipe to connect to the carb
i am using a eletric fuel pump
shortie
posted on 15/5/05 at 09:49 PM |
yep, should be fine, that's what me and alot of others are using.
Rich.
NS Dev
posted on 16/5/05 at 07:24 AM |
Are you sure that you don't want 8mm??
I don't know your application but I know that I used 8mm microbore copper tubing, as the 5/16" fuel lines (as used on most cars) are a
direct push fit over the ends of the copper. I swage a rib onto the ends of the copper pipe using a flaring tool to stop the rubber blowing off
(injection lines)
Possibly your lines are bigger, perhaps 3/8", but I don't know, if so, ignore the above!
