Author: Subject: Zorst
jonbeedle
posted on 23/5/05 at 05:22 PM Reply With Quote
Zorst
Trying to fit a stainless zorst off a Stryka. Looking at the following pics it looks as though I'll have to cut out the diagonal chassis tube and reposition it.
Any thoughts peeps?
Advice gratefully received.
By the way the big hole is there because it had a different exhaust before!
Jon
[Edited on 23/5/05 by jonbeedle] Rescued attachment Dscf0004.jpg
"Everyone is entitled to an opinion however stupid!"
jonbeedle
posted on 23/5/05 at 05:23 PM Reply With Quote
jonbeedle
And from inside......
jonbeedle
posted on 23/5/05 at 05:27 PM Reply With Quote
The engine has been jacked up and it's not central. To get it in the right position I think the black tube will have to go!
Jon
DavidM
posted on 23/5/05 at 07:40 PM Reply With Quote
Hi John,
In my opinion cutting that particular tube out would seriously compromise the integrity of the chassis, as it is the main brace to the front of the chassis and suspension mounts.
Would it be possible to move the engine further back, such that you have a bigger hole to aim at in the area at behind the brace. If not I'd suggest modifying the manifold to achieve the same thing.
Alternatively you could modify the manifold to exit above the chassis rails through the bonnet.
[Edited on 23/5/05 by DavidM]
Proportion is Everything
jonbeedle
posted on 24/5/05 at 01:40 PM Reply With Quote
Hi David,
I think I'll do it like the Avon......
[Edited on 24/5/05 by jonbeedle]
jonbeedle
posted on 24/5/05 at 01:58 PM Reply With Quote
