Author: Subject: Zetec-MT75
Dr. Bob
posted on 31/5/05 at 03:41 PM Reply With Quote
Zetec-MT75
Hi there,
Can anyone of you help me out. I'm going to connect a 1.8 zetec engine to a MT75 gearbox. I already have the right (standard) flywheel and clutchplates but do not yet know what bearings I should use. I have understood that a spigot bearing is needed to support the gearbox input shaft, but what type/artnr do I need? Secondly I need a special/modified releasebearing. I saw that Westfield is offering this special releasebearing for 55pound (in euros it's even more) but I hope that someone can suggest me a cheaper solution.
Thanx in advance,
Dr. Bob
big_wasa
posted on 31/5/05 at 04:35 PM Reply With Quote
I think the standard spigot bearing from the sierra (any) is the one for the job.
Release bearing does indeed need moding, it requires a 19 mm spacer glued on to the standard sierra mt75 item..I diidnt fancy the idea of gluing the two together and picked up one on ebay that had only done a few miles for about £12 This was a westfield one and it was a standard ford bearing with a 19 mm spacer glued on ..Im pleased I didnt pay £55 quid for it...
I understand that the standard mt75 bearing cannot be purchased on its own from ford or anyware elts(may be wrong and often are) So if you havent got one to mod then the westie one is easier allround.....
If you get stuck for one ,and can find me a peice of bar stock ill turn you one up on the lathe,I even have a couple of bearings on the work bench(need a good clean ) BUT you will have to glue it your self....
Have a search on here a few have made there own........
big_wasa
posted on 2/6/05 at 07:47 PM Reply With Quote
Just to confirm the spigot bearing for the mt75 engine /box fits..I paid a tenner at Fords today..Tapped it in gentlly with a socket and a rubber hammer...
The guy at fords said the part number, and the part itself is differant for the type 9's and the mt75's???????????????
zetec
posted on 2/6/05 at 09:17 PM Reply With Quote
Dunnel do a clutch which uses a standard Sierra MT75 release bearing, no need to mod at all. The problem is I did'nt take a note of the clutch part numbers, but if you are buying a clutch give them a call. Their sump and modded flywheel are good kit too.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
big_wasa
posted on 2/6/05 at 09:47 PM Reply With Quote
Dunnel's stuff does look nice ,I nearly had there alternator and brackets but went locost As for the sump and flywheel Ive already been to Scholar engines who also do some nice stuff
saigonij
posted on 2/6/05 at 10:27 PM Reply With Quote
my microcat says that all spigot bearings are the same for ford engines that have them
saigonij
not that i have microcat you understand
big_wasa
posted on 3/6/05 at 08:29 AM Reply With Quote
