NS Dev
posted on 10/6/05 at 11:58 AM |
ok, where does this come on the dodginess scale???
dodgy engine perhaps??
Danozeman
posted on 10/6/05 at 02:28 PM |
Looks good to me. The supercharger looks like a turbo though.
Dan
alister667
posted on 10/6/05 at 02:57 PM |
I'd say that would be a lovely engine in a cobra replica.
I'd just check the engine no. hasn't been gound off.
http://members.lycos.co.uk/alister667/
flak monkey
posted on 10/6/05 at 03:23 PM |
No its a supercharger.... Nice
Sera
http://www.motosera.com
MikeR
posted on 10/6/05 at 04:40 PM |
Nat don't do it, get the saab for your class 7 grasser ..... if you get that (irrespective of dodgieness) i'll be forced to have a drive
for the sheer hell of it!
tks
posted on 10/6/05 at 07:07 PM |
what the hell
is the difference in an turbo and an super charger??
don't have looked at the pic yet..
TKs
flak monkey
posted on 10/6/05 at 07:10 PM |
A supercharger works at all rpms providing a constant boost pressure. A turbo doesnt, it provides more pressure at higher rpms. Well i think so
anyway...lol
Superchargers are usually driven off the crank shaft, some are electric though. Turbos are driven by exhast gas pressure.
Sera
Dale
posted on 10/6/05 at 08:42 PM |
Pretty sure a supercharger is linear in boost as its fed by the crank via belt, You get some boost right off of idle and up, tuned to the maximum
boost level at max rmp I think. Turbo is fed from exaust under load so there is little paristic load but you get alot more plumbing and heat to
contend with and no real benifit at lower rpms , depending on your sizing of the turbo determins the point under load that the turbo will hit boost.
Setting of a waste gate ( a vavle that bypasses some exhaust around the turbo ) allows you to set your maximum boost level as oposed to having to
change pullies on a supercharger. The waste gate setting can be controled in the car to lower or incrase your maximum boost. Big difference is on a
turbo you can have maximum boost say at 3000rpm and keep it there till redline where with a supercharger you get max boost at max rmp.
Then again I may have my head up my ass again.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
berkut
posted on 11/6/05 at 07:56 AM |
This depends on the type or supercharger you are using... On a lysholm / roots / G ladder supercharger the boost is always the same, corelated to the
rpm. 0.5bar all the way from the bottom
In a supercharger with a centrifugical compressor like the one above the boost comes up as the rpm raise hitting max at max rpm and is more like a
turbocharger with a large boost creep or waste gate opened wide.
NS Dev
posted on 11/6/05 at 08:49 AM |
berkut sums it up perfectly!!
