Author: Subject: MT75 three prong flange. What thread?
garage19
posted on 17/6/05 at 08:10 PM Reply With Quote
Just bolting my prop up.
I have new Ford bolts for the diff end but as i have removed the rubber damper from the MT75 i need to get my own bolts.
I have tried some M12 bolts but they are not the correct thread pitch
Does any one know what the thread pitch is?
As the bolts will be under a shearing force, should i use 8.8 or 12.9 tensile bolts?
Doug.
The Stoat
posted on 18/6/05 at 11:02 AM Reply With Quote
I have some used ones (off of a type 9 if they are the same) if you would like.
The Stoat.
Some are born stupid, I had stupidity thrust upon me.
Mix
posted on 18/6/05 at 02:41 PM Reply With Quote
If you still have the 'studs' that held the 'do'nut' on then why not cut off the surplus thread and use them?
Mick
tks
posted on 18/6/05 at 02:50 PM Reply With Quote
8.8 should do the trick..
diff bolts are M10, 1mm pitch (metric)
sow i guess it an easy task..
Tks
garage19
posted on 18/6/05 at 10:14 PM Reply With Quote
Nope, unfortunatly i filed them at an early stage of the build!
Mick
garage19
posted on 18/6/05 at 10:16 PM Reply With Quote
Tks
As i said already got new diff bolts, its the gearbox end im stumped
Mix
posted on 19/6/05 at 08:28 AM Reply With Quote
OK I've just dug one of the original studs out. The thread is 12mm 1.75 pitch.
If that's the size you tried before I suggest you look at cleaning the threads as Ford had used their blue thread locking compound on mine and it could be that making the thread stiff.
Mick
garage19
posted on 19/6/05 at 03:16 PM Reply With Quote
Many thanks Mick.
Is 1.75mm standard M12 pitch or coarser?
Will go and check the pitch on the bolts I have.
Thanks,
Doug.
Mix
posted on 19/6/05 at 03:29 PM Reply With Quote
As far as I'm aware that's the standard pitch. Good luck
Mick
