Peter M
posted on 19/6/05 at 09:23 PM |
fuel filter position
Running 1.8 zetec with fuel injection mounted the injection fuel pump low down i.e level with the fuel tank outlet.What i need to know the fuel filter
that is going to be fitted down stream of the pump is it ok to fit this at say at a height level with the top of fuel tank.Would this have any adverse
effect.
stevebubs
posted on 19/6/05 at 10:06 PM |
Your injection pump should have a maximum lifting spec.
Should be fine.
Out of interest, why are you using a post-pump filter? I've used pre-filters on both my lift and injection pumps.
wilkingj
posted on 19/6/05 at 10:32 PM |
I always fit my filters before the pump... Its stops the crap in the tank from wearing out your nice expensive pump.
I usually have one before the pump, and one just before the carb / injectors... A Bit overkill I know.
Best Regards
Geoff
http://www.v8viento.co.uk
Peter M
posted on 20/6/05 at 08:00 AM |
Thanks for the advice . Im putting the filter after the pump as talked about in previous filter threads. Seem pumps dont like sucking thro filters?
Also when i have replaced metal encased filters on tin tops they seem to be in the engine side of fuel pump.
Peter
JAG
posted on 20/6/05 at 10:33 AM |
The Mazda filter system (as on the MX5) is a low pressure filter, in the tank, and then a high pressure filter after the injection pump but before the
injectors.
Mounting the high pressure filter higher than the pump is probably fine but check the pump spec' - as Steve said.
[Edited on 20/6/05 by JAG]
Justin
ChrisGamlin
posted on 20/6/05 at 11:16 AM |
Ive gone for one either side too, a low pressure one to stop crap getting into the pump from the tank, and a high pressure one to prevent the
injectors being screwed if the pump decided to start breaking up and sending its own crap down the fuel line.
[Edited on 20/6/05 by ChrisGamlin]
zetec
posted on 20/6/05 at 02:57 PM |
Second that vote for pre and post pump filters. I've recently checked my pre pump filter and found plenty of rubbish which would have jammed the
pump. The cost of a post pump filter is a few quid and saves any hassle if something does get into the injector feed.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
stevebubs
posted on 20/6/05 at 04:52 PM |
Peter
So long as your pump is gravity fed (i.e. lower than the tank) then you shouldn't have any problems with a pre-pump filter.
