Author: Subject: zetec engine mounts
Markp
posted on 26/6/05 at 09:14 PM Reply With Quote
zetec engine mounts
Hi All,
I managed to get my hands on a 2l zetec black top engine Are the engine mounts the same as on a silver top? Does anyone have any pictures how they did the mounts for the zetec?
As always your help is greatfully received.
Mark
zetec
posted on 26/6/05 at 10:43 PM Reply With Quote
I placed my engine and gearbox within the chassis resting on blocks (or a workmate if working with the chassis off the ground) then decided on what rubber mounts to use. Once this is known you can use card or thin ply to make up some box section mounts to have fabricated in steel. MK made mine from my pattern and very well done. The hardest bit is getting the engine and gearbox placed in the chassis so that everything will fit when complete. Things like the oil filter and inlet system are the hardest on the zetec as the steering column are on the same side. All sounds harder than it is. I've got a few old pics but too big to post, let me know if you need some and I'll email you.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Markp
posted on 26/6/05 at 11:10 PM Reply With Quote
ZETEC
you have u2u
mark
stevebubs
posted on 27/6/05 at 12:29 AM Reply With Quote
Originally posted by Markp
Hi All,
Yes
Markp
posted on 30/6/05 at 09:14 AM Reply With Quote
zetec
Thanks for the photos mate. just what I was after
Mark
